Ok Sub-Frame Connectors again. Please Advise
Old Nov 13, 2001 | 05:55 PM
SLP_GTA's Avatar
I've read all of the topic on SFC and I have decided to buy the bolt in and weld them in afer awhile. My question is, WHICH ONES??
I have duals cats with SLP headers and exhaust, I want to buy the best fitting SFC price is not a issue quality is. Have you found any powercoated red??
Please provide links or suggestions, thanks in advance.
Old Nov 13, 2001 | 08:45 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
glad to see you are going bolt in. I have jegsters, they work well.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 13, 2001 | 11:45 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
www.spohn.net
'Nuff said
Kat
Old Nov 14, 2001 | 07:48 AM
Steve10's Avatar
I purchased the Spohn's last week. If you have a SLP y-pipe you may have fitment problems on the passenger side. I got under the car and took a few digital pics of my exhaust and sent them to Steve Spohn. He said that he had just done an install on a care with SLP exhaust and will now be offering a "SLP version" subframe. That's what I ordered. UPS will deliver them today, so I haven't actually seen them yet. If you go with Spohn, call him up and talk it over.
'87 Formula WS6 - ZZ4 Crate TPI, Scroggin-Dickey ported heads, LT4 hot cam, 1.6RR, Accel runners, Accel base, ported plenum, Edelbrock 58mm TB, Crane Fireball ignition, SLP cold air, SLP 1 5/8 headers, !cat, Summit exhaust cutout, Walbro 255, Koni yellows, Hotchkis panhard & LCA's, 9 bolt w/3.27's.
Old Nov 14, 2001 | 11:57 AM
Momar's Avatar
Do you think that the slp version would fit on a car that is currently still a stock single cat, because I plan on changing that in the future. Would it matter if I went with the single or dual cat setup. I want to go with the dual cat setup but minus the cats so I can get better flow.
[This message has been edited by Momar (edited November 14, 2001).]
Old Nov 14, 2001 | 12:01 PM
Momar's Avatar
Oh yeah, gofaster why did you say that you were glad to see he was going with bolt in, I thought that weld in were better.
Old Nov 14, 2001 | 01:50 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Weld ins are much better.
They are definitely more rigid and make a "true" frame instead of a "bolt-in" frame that may over time gain unwanted clearences.
And I would definitely recommend Spohn components.
I have done the research, and his are definitely top notch products.
13.2 @ 102.6MPH 60 degrees w/ still no tuning on motor
raven
Custom EFI Intake Setup
Old Nov 14, 2001 | 03:47 PM
SteveSpohn's Avatar
I get asked this ALOT, I need to add an exhaust compatibility FAQ to my SFC page, which I will do. Here ya go for future reference:
Spohn Single Cat: Will fit stock single cat, Hedman single cat, Edelbrock TES single cat.
Spohn Dual Cat: Will fit stock dual cat and SLP dual cat.
Spohn SLP version: Will fit the SLP single cat y-pipe.
If you have a single cat now, and have future plans to upgrade to a dual cat or a SLP single cat, either version WILL work with a single cat set up.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Nov 14, 2001 | 06:00 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The Spohn SFC's are without a doubt the best. I have them on my '82 Z28 project car.Soon to be on my '86 IROC Z. They are GREAT.
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
Tweeks25
Sep 17, 2015 08:04 AM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
