Pics of the 89-92 rear discs
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I would like to see some pics of this setup. Also, what is considered the right and left of the car? When looking from the rear to the engine, is my left the left hand side or vice versa.
Awhile ago someone was kind enough to send me a pic of the axle flange.. can he or someone that has one send it to me? I can't quite figure out the orientaion of the caliper and which mounting braket to use.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Left and right refer to the car's left and right, which is the same as yours when you're sitting in the driver's seat facing forward.
This is the disc flange:
<img src=http://members.home.com/crussel/disc.gif>
And this is the drum flange:
<img src=http://members.home.com/crussel/drum.gif>
All the parts together look like this:
<img src=http://members.home.com/crussel/rear_pbr_disc_assy.jpg>
Just in case its useful too, the caliper explodes like this:
<img src=http://members.home.com/crussel/rear_pbr_caliper_explosion.jpg>
[This message has been edited by Apeiron (edited November 14, 2001).]
Engine: LS1 / LS3
Apeiron, you rule!!! Do you have access to the part numbers for those parts?
Engine: 383 Carb
Transmission: 4L60
Sure, which ones? I've been collecting info to convert the Moraine discs on my 84 to PBR's.
Engine: LS1 / LS3
Well...as far as the top picture: 36 38 39 26 32 34.
Do you know what comes with the caliper? I will need all of the ebrake parts so worst comes to worst: 2 3 4 5 6 7 8 9 10 11 13 23 24.
Where did you get those assy. views?
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I bought rebuilt calipers from Autozone when I did this upgrade on my 82.They came with all the e brake parts already on them,all I had to get was caliper mounts,pads,backing plates,rotors,e brake cables,and of course the calipers.The shims are no longer available through GM so I made my own out of flat brass shim stock in various thicknesses.Right and left of the car is considered as if you are standing at the back of the car looking towards the front,your left is cars left and vice versa.
1982 Z28:355,4 Speed,Lots of bolt ons
Engine: 383 Carb
Transmission: 4L60
Ok, for the top diagram:
<table border=1><tr><td>26</td><td>Stud</td><td>9590476</td><td>Hopefully you already have a few of these on each side.
</td></tr><tr><td>32</td><td>Rotor</td><td>10087702</td><td>Get these from any parts store.</td></tr><tr><td>34</td><td>Bolt</td><td>10097602</td><td>M12 x 1.75 x 21</td></tr><tr><td>36</td><td>Shim</td><td>26013017, 26013018, 26013019, 26013020</td><td>These are discontinued, but as mentioned, you can make your own. Shims are necessary to center the caliper carrier around the rotor. Required thickness varies.</td></tr><tr><td>38</td><td>Lockwasher</td><td>9439513</td><td>7/16 x 25/32 x 7/64</td></tr><tr><td>39</td><td>Nut</td><td>225854</td><td>3/8 x 24</td></tr></table>
The calipers do not come with 10, 13, 14 or 28. These are:
<table border=1><tr><td>10</td><td>Guide Pin Bolt</td><td>14067559</tr><tr><td>13</td><td>Guide Pin</td><td>14067560</tr><tr><td>14</td><td>Guide Pin Boot</td><td>14067552</tr><tr><td>28</td><td>Caliper Carrier</td><td>10112652</tr></table>
[This message has been edited by Apeiron (edited November 15, 2001).]
</td></tr><tr><td>32</td><td>Rotor</td><td>10087702</td><td>Get these from any parts store.</td></tr><tr><td>34</td><td>Bolt</td><td>10097602</td><td>M12 x 1.75 x 21</td></tr><tr><td>36</td><td>Shim</td><td>26013017, 26013018, 26013019, 26013020</td><td>These are discontinued, but as mentioned, you can make your own. Shims are necessary to center the caliper carrier around the rotor. Required thickness varies.</td></tr><tr><td>38</td><td>Lockwasher</td><td>9439513</td><td>7/16 x 25/32 x 7/64</td></tr><tr><td>39</td><td>Nut</td><td>225854</td><td>3/8 x 24</td></tr></table>The calipers do not come with 10, 13, 14 or 28. These are:
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
