questions about adjustiable shocks???
Old Nov 12, 2001 | 10:21 PM
poncho9789's Avatar
I am wanting a set of shocks that will be good for street performance (conering) and strait line traction dragracing on the track and street. Lets say I was to buy a set of adjustable shocks. Would I be able to adjust to a setting of 50/50 in the rear and 70/30 in the front on the weekends. Durring the weak I want to adjust to a vary firm setting for street performance.
89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body, Ported Edelbrock centerbolt heads,Accell 30# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NOS. My baby is going back togeather soon.
Old Nov 13, 2001 | 01:18 AM
BTS88IROC's Avatar
Yes you can adjust them like you said. I'm not sure if you can adjust them all to exactly like 50/50 or 70/30 like you want though. But there are just different levels of settings. You will have to see what you like best. There are several companies out there that offer adjustable shocks. When I upgrade I'm going with some Tokico's, which are 5-way adjustables. I think Koni makes some too.
Old Nov 13, 2001 | 09:05 PM
nicmike85's Avatar
Be sure to ask alot of questions about the shocks your going to buy. Most adjustable shocks are only adjustable on one side. Most cases this is the rebound rate. A double adjustable allows you to adjust the rebound and compression strokes. Your classic 90/10 front drag shock has a loose rebound and a very hard compression stroke. As far as adjustability goes I don't believe there is alot of adjustment. Rear shocks have minor adjustment as the fronts have a wider range of adjustment. You may find a problem finding a shock that adjusts from 90/10 to 50/50.
Old Nov 15, 2001 | 11:24 PM
poncho9789's Avatar
What I am wanting is a shock that will go to something like 40/60 to a stiff firm rait in the back and something like a 60/40 that will adjust to a stiff rait to allow me to transfer weight when on the strip and will also allow me to adjust to a firm (tight) feal on the street.
If anyone has any suguestions as to what shocks might do this for me please make them known. I still have the stock WS6 shocks that came on my car in 89 they really need to be replaced.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
