nominal tire diamater
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What's the nominal tire diamater of an IROC with stock wheels and tires? I need to know for a calculation.
Thanks for the time
Robert
Thanks for the time
Robert
15 or 16 inch rims? if 15's, 215/65r15's, from top of tread to bottom of tread is 26.0039 inches on a perfect tire calculation, ie brand new closely toleranced. for most calc's, just use 26 inches. 16's. specifically 245/50r16's, 25.6457 inches, again under perfect conditions. for most calcs, 25.5 or 25.6 will do.
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
Or you could go to www.tirerack.com, look up the specific brand and model of tire, click on "specs" and read all the dimensional data for your size off the table. Wheel width info is also provided. Note that the dimensions of different tires of the same nominal size differ slightly.
1979 Malibu w/some cornering tweaks and a few other interesting things
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Linson
Oct 1, 2015 09:50 PM
