what do I need to fix my steering?
Old Nov 16, 2001 | 11:10 PM
matthew's Avatar
Well I was changning my oil today, and while I was at it, I greased the joints in the whole steering system. As I was looking at it I thought to myself that it would be really easy to replace everything. Just a simple unbolt and bolt back in. I am thinking of doing this because ever since I got my new tires, my car likes to wander when driving, and It always goes to the low spot in the road, I think this is because of the 15 year old steering joints. So would replacing the center link, idler arm, and pitman arm help my car drive straight? What parts do I need exactly? I was thinking about getting all new moog parts.
yellow 86 Camaro
LG4 700R4
ROH RH 17x9
Bridgestone Potenza RE730 255/45ZR17 all around
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Now KYB equipped!!
Old Nov 17, 2001 | 06:12 AM
Jza's Avatar
Jza
I'd say 80% of the reason the car tramlines is the wider tires, and 20% could be possible steering slop. You wouldn't need to replace the idler arm or pitman arm unless they got bent somehow (there's no parts to wear). Replacing the center link and inner and outer tie-rods and the ragjoint in the steering shaft will definitely make a change for the better if there's any wear in your steering. You'll need a tie-rod puller (I don't really like the pickle fork). Moog's a good choice.
Old Nov 18, 2001 | 05:18 PM
matthew's Avatar
So theres no hope in curing my tramlining? I don't want to put my old narrow tires back on just so I can steer better. Does everyone who has wide tires have this problem?
Old Nov 18, 2001 | 06:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by matthew:
Does everyone who has wide tires have this problem?</font>
Yep
Old Nov 19, 2001 | 08:06 AM
82camaro's Avatar
Car: 82 camaro SC
Yes wide tires are a large part of the problem. But loose steering linkage and wide tires are really bad. The idler arm 'is' a wear item and is commonly the first part to wear out. If your not sure how to check everything out, have a front end shop do an estimate--then install the parts yourself.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 22, 2001 | 04:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
On my car, the Idler arm and Center link wore out, had a little play in them, pitman arm is solid.
WS6 Trans Am.
View My Ride @ thirdgen.org
83 Crossfire TA
Jan 3, 2016 01:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
