sway bar q's
Old Nov 20, 2001 | 02:39 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
sway bar q's
i have an 87 camaro lt. i would like to install front and rear sway bars from an iroc. will this install go without modification? how much bar diameter will i gain from this and how much better will the car handle corners?
87 Camaro LT
bone stock 305 w/ 700r4 0-60: 3 minutes
mods to come:
ground effects
93 camaro seats
99 camaro center console
91 z28 rims
white 145mph iroc gauges
Old Nov 20, 2001 | 06:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The swap should be a simple bolt-up (while you're doing it, install GM's or Global West's wonderbar). When I swapped to the 1LE version, hollow 36 mm front and solid 24 mm rear, I also used 1LE higher durometer bushings and poly end links. I don't push my old guy very hard, but I sure like the feel.
Old Nov 20, 2001 | 01:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Get your "poor-man's calipers" out... that's an open-ended adjustable wrench. Snug it down on the center of each bar, and then measure it on a ruler, or "trace" the jaw width on a piece of paper. Take the paper or the ruler, along with the open-ended wrench, when you go to the junkyards.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 25, 2001 | 02:44 AM
pianiy's Avatar
I just went from 30mm front (solid)/18mm rear (solid) to a 36mm front (hollow)/23mm rear (solid) bars from a WS6 TA with poly endlinks and bushings. I also installed a wonderbar while I was at it. I've only driven the car for a few miles now and its not a night and day difference but it definitely helps. Stiffer springs will also help you plant the tires better because thats what the bar is really pushing against.
If you pull the bars out of an Iroc, the largest diameter front will probably be 34mm.
~Luke
'91 Firebird :: L03/700R4 ::
Mods: Catco cat - Flowmaster 80 series - B&M Shift kit - TA tail lights - GTA rims - K&N - MacEwen guages
Stereo: Pioneer DEH-P8200R - Cadence 4x6's - Pioneer 6x9's - Kicker amps - Kicker 10" CompVR
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
