replacing master cylinder and power booster/master
Old Nov 26, 2001 | 05:12 AM
camaro84boy's Avatar
Just had a questions for all you knowledgable out there when it comes to brakes. Just want to know how much trouble, if any, to remove and install a new master cylinder and power booster or master, whatever they call it? Not necessarily on a camaro but just in general. My aunt has an 80's pontiac parisienne, needs these 2 things, only front brakes working, was previously diagnosed by a brake shop, but told her it would be $650 -just brakes- When I called around I found I could get master cylinder for $20 remanufactured and power booster for $142, diff of abt $490-wow! What is it with these brake shops, do they think people just have rooms of money to spend, I know they have to make money, but what a markup! Anyhow I thought maybe I may have a chance at it (with some help)but wanted to know if any of you out there have changed these on your cars to see what I may be in for, otherwise what suggestions you may have. Thanks a lot.
Old Nov 26, 2001 | 07:38 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
The shop doesn't presume anything about your aunt or anybody else. It's not parts markup that's making the price so high (well, some of it is). It's LABOR. Do it yourself and ask how much you'd charge somebody to do it again. It might not be $600 but it wouldn't be free I bet. These shops are in business because people need people like them to do this kind of work...It's called capitalism, get used to it.
Now...off my soapbox...
It's not that difficult to replace these pieces. The master cylinder is a no brainer. The booster will be a pain. You have to take the nuts loose from inside the firewall...up under the dash, and that is what makes it no fun (thus the $600 bill)
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
http://communities.msn.com/clemsprojects
Old Nov 26, 2001 | 08:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Bleeding the master cylinder might be a pain in the butt; I've changed quite a few m/c's on my car, and every single one I've done, I always get these minute little air bubbles when I bench bleed. No amount of bench bleeding gets rid of 'em... and I'm doing it all by the book, too... go figure. A Mityvac ( http://www.eastwoodcompany.com and http://www.mityvac.com ) might help; there are also some "pressure bleeders" out there if you do a search through yahoo.com .
-Tom P (Hot rodded 1986 Firebird 2.8l)
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
