Question about The frame area where the rear LCA's attach to car???????????
Old Nov 26, 2001 | 10:06 AM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
That flat frame like area just in front of the rear Lca's connection,I quess its the frame, Are both bent upward like they caved in. One is bent upward about 3/4" the other not as bad. The worst side caved in when I jacked the car up a while ago from that point. Will this have an effect on anything???? Can and should it be repaired????
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
[This message has been edited by john5.7 87Iroc (edited November 26, 2001).]
Old Nov 26, 2001 | 10:07 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
double post
Old Nov 26, 2001 | 02:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I never had mine cave in... did you use a bottle jack (thin jacking point) in that spot? It might weaken it a bit...
-Tom P (Hot rodded 1986 Firebird 2.8l)
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
NBrehm
Aug 5, 2015 07:57 PM
