disk rear
Old Nov 26, 2001 | 09:31 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
disk rear
I have an 83 camaro z28 with a 305 auto. i am courious about adding rear disk brakes, and maby anti lock. and info would be appr.
Old Nov 27, 2001 | 08:53 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
If you want all the info for the disc swap, goto the main page of this site. On the left hand side look where it says "Tech Central" Then under that there will be "Technical Articles" scroll down to the brake section and there will be an article called "How to upgrade your brakes" That will give you all the part numbers you need. If you read the last article in that section... the one about installing LS1 discs to your drum rear, the installation is very similar.
As for ABS, not worth the hassle.. know your cars limits, and your own.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
