86 iroc alignment
Old Nov 26, 2001 | 05:50 PM
Idagon's Avatar
86 iroc alignment
i have an 86 iroc andjust had it aligned.
i told them -.5 camber both sides
and 5* left and 5.5* right caster
they told me the most caster they could get out of it was 3.2* left and 3.8* right
they did get-.5 camber
does this caster sound right?
i thought 86 irocs came with 5* caster
after they finished the car seems to wander a bit
Old Nov 26, 2001 | 08:40 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Idagon:
</font>
specs are as follows:
camber 0.50 +/- 0.50
caster 3 +/- 1
total toe 0.30 +/- 0.20
all in degrees
can you get more? possibly. may need to take the top off and elongate the holes more. but, to answer your question, yes it sounds right. i run an alignment shop and mine is 2.74 left and 3.11 right. your wander might be toe. what is it set at?
Old Nov 26, 2001 | 09:48 PM
Idagon's Avatar
toe is set at 3/32
Old Nov 28, 2001 | 10:28 PM
mrr23's Avatar
Engine: 360 HSR
toe is set at 3/32</font>
wander could be play in the steering box or tie rod starting to go bad and they didn't catch it.
mrrjjdh03@aol.com moderator at www.fl-thirdgen.org
Old Jan 7, 2002 | 05:45 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
If its the steering box, then that can be adjusted correct?
Old Jan 7, 2002 | 05:56 PM
mrr23's Avatar
Engine: 360 HSR
86 iroc alignment
yes the gearbox can be tightened by loosening the jamnut on top of the box and turning the center screw clockwise one turn with an allen wrench. then tighten the jamnut.
sunbound
Sep 5, 2015 11:52 AM
g.l.mos
Aug 22, 2015 12:02 AM
383backinblack
Aug 15, 2015 06:36 PM
mustangman65_79
Aug 11, 2015 03:17 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
