88 9 bolt for 200 good deal or not?
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
I currently have a 90 RS with 273 gears and drum brakes. I found a 88 9 bolt with 3.45 gears limited slip, and disc brakes. Should I go for this or not. I can have anything off the car related to this swap for $200. Will I run into any major problems when swaping these 2 rear ends?
1990 Camaro RS
1991 Acura Integra LS
check out my site: <A HREF="http://www.geocities.com/joecool_2u" TARGET=_blank>
</A>
LT1 motor stuff so far:
TPIS ZZ-9 cam, Comp Cams 1.6 Roller Rockers, Comp Cams "R" Lifters, Crane Cams Dual Valvespring kit, Underdrive pulley, and an air foil.
383 LT1 Stroker project has begun.
1990 Camaro RS
</A>
Car: 1983 Z28
Transmission: WCT5
I'd say is was a pretty fair deal. The 3.45s seem hard to find. Apparently the '89 and later brakes were the good ones (PBR), but that shouldn't be a difficult upgrade if you find it necessary.
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
http://communities.msn.com/clemsprojects
Clem
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'd do it, but I would look for a set of 89-up rear brakes to put on it even if those 88s work fine. You could always put them on later. I picked up an 89 9-bolt with 2.77s with the complete brake setup and I'l swap to 3.27s when I get to it.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The problem with putting early brakes on the '90 and up is you have to change the whole parking brake mechanism.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
86IROC112
Aug 17, 2015 02:00 PM
