rear brakes
Old Nov 27, 2001 | 05:11 PM
1991GTA's Avatar
rear brakes
need help with rear disc on 91 GTA,changed calipers,(reman),pads, reman master cyl.,rear wheels will still turn with car jacked up and standing hard on brake pedal,e-brake still no good,adjusted according to mitchell repair book, these are not self adjusting,adjustment made at caliper.blead every thing,no air in system,.any help is appreciated..
Old Nov 29, 2001 | 10:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i wish someone knew what was wrong with our brake systems. i have the 89+ system. i have replaced the ENTIRE brake system and bled it. i have the same problem and the damn wheels keep turning.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited November 29, 2001).]
Old Nov 30, 2001 | 09:44 AM
TVP's Avatar
TVP
well .. basically the master cylinder provides pressure .. the pro valve regulates it .. the calipers respond to the pressure .. if your wheels don't lock ..then the pressure isn't getting there ..or.. it's getting there and the caliper is not repsonding to it ... with the facts you state and I *** -u-me you know how to properly perform all the work .. i'd say the pro valve is junk .. when you bleed the brakes , does the fluid SPRAY out of the fitting ..or just droooool out ??? if it sprays out like it should .. I'd say the calipers are locked or not adjusted ... if you can't even lock the ebrake .. and again *** -u-me-ing you have all the right parts and they are installed correctly ... then they ARE out of adjustment ....
Old Nov 30, 2001 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey guys; with your cars off, if you pump the brake pedal to the floor 8 or 9 times, and then pop the m/c reservoir cap- do you have a ton of small air bubbles in the reservoir closest to the firewall? I've bled the hell out of my brake system (the 84-88 one), and find no air in the lines- but I get those tiny bubbles after pumping the brakes. It makes me wonder if I'm missing a pocket of air somewhere... it'd be good to know if other cars do it.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 30, 2001 | 01:25 PM
TVP's Avatar
TVP
TomP ... top off your fluid ..ALL THE WAY TO THE TOP .. and put the lid back on .. fluid should spill over if you do this right ... then try your trick .... if you try your trick with the lid off .. fluid WILL spray all over !! ... that's why you get bubbles .. the fluid is moving like mad ..with a little air in the MC you'll get a mix with air ...
Old Nov 30, 2001 | 02:05 PM
SoCo80p's Avatar
you MUST have a parking brake cable! you can bleed 10 gallons threw it and nothing will happen, convert over to the disc brake e-brake cables and you will be fine, also you need the proportioning valve off a 4WD disc car for the brakes to work right,
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
