visual differences in calipers
Old Nov 26, 2001 | 10:11 PM
TexasLT1's Avatar
Car: '92 RS
is there any visual difference in the pre- and post-89 calipers? I have an '87 IROC rear sitting in my garage, but I just got a complete '91 disc setup from Ebay and the calipers look the exact same. the axles are obviously different but not the calipers. whats going on here?
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
-'95 Camaro Z28
-'88 Firebird
-'99 Ford Lightning
-'01 Camaro SS (OH YEAH BABY!!!)
-'96 Turbo Eclipse
-'99 Mustang GT
-'01 Nissan Maxima
Losses
-'01 Mustang GT
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
FOR SALE: complete '87 IROC 9-bolt disc brake rearend. rebuilt calipers, powder coated axle housing, painted calipers and backing plate, all brake lines included. needs rotors and driver's side dust shield. The gears are in VERY good condition, low mileage, no signs of wear. make offer
Old Nov 26, 2001 | 11:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There are substantial differences. The early calipers are steel. Laster ones are aluminum with ribs cast into the outside.
Old Nov 27, 2001 | 11:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do you have the axle's code handy? ("Front" of passenger side axle tube) Maybe it wasn't a '91?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 27, 2001 | 02:09 PM
TexasLT1's Avatar
Car: '92 RS
no I didnt get the axle tube, I just got all of the hardware. axles, rotors, calipers, pads, brakelines and proportioning valve. I better not have just gotten screwed because I already have a complete '87 disc rear in my garage.
Old Nov 27, 2001 | 05:01 PM
TexasLT1's Avatar
Car: '92 RS
ok, I just e-mail the guy and asked him about the calipers and here is what he said:
"All that is in the picture is what you bid on , look at the picture. not all 89-92 camaros had the aluminum calipers, I took all of these parts off of a 91 10 bolt"
I thought EVERY car from '89 up had the new style caliper. am I wrong or did I just get screwed because he doesnt know what year they are off of?
and if it helps, here is the auction on ebay:
http://cgi.ebay.com/ebaymotors/aw-cg...item=597315926
Old Nov 28, 2001 | 10:11 AM
TexasLT1's Avatar
Car: '92 RS
ttt
Old Nov 28, 2001 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Maybe -he- can get the axle tube #? I didn't think those old-style calipers were around after '88, either... could the axle he got have been under a '91, and it was swapped before he got there?
Old Nov 28, 2001 | 01:07 PM
TexasLT1's Avatar
Car: '92 RS
thats what Im beginning to think is that it was swapped before he got to it. I'll e-mail him today and see if he'll give me the axle tube code. if he doesnt then I'll know that he knew it was swapped.
-Heddman Headers
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'95 Camaro Z28
-'88 Firebird
-'99 Ford Lightning
-'96 Turbo Eclipse
-'99 Mustang GT
-'01 Nissan Maxima
Losses
-'01 Mustang GT
-'99 Mustang GT
-'96 Mustang Cobra
Old Nov 29, 2001 | 08:47 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
89-92 disc brake cars ALL got the aluminum calipers. It could have been swapped.
Old Nov 29, 2001 | 09:32 AM
gravitar's Avatar
Thoase parts look just like the stuff I pulled off an '84 TA. Methinks you've been had..
Old Nov 29, 2001 | 09:53 PM
Abubaca's Avatar
89 and later also had 11.65 dia. rotors instead of 10.5 inch dia. how big are the rotors? I don't know if the steel cals would bolt to the bigger rotors?
Old Nov 29, 2001 | 10:17 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You been had, sorry!
Go here to see right one for '91
http://cgi.ebay.com/ebaymotors/aw-cg...item=598340573
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
[This message has been edited by Dyno Don (edited November 29, 2001).]
Old Nov 30, 2001 | 11:04 AM
TexasLT1's Avatar
Car: '92 RS
D*MNIT!!!! this sucks, I kinda figured as soon as I pulled the stuff out of the box that it wasnt right. well, I'll still probably use them anyway now that I've got them unless I can get rid of them for the new ones. doubtful but I'll try. since the parts are from an older one and I've got a '92, will the axles even work? The '87 IROC rear Ive got in the garage has unequal length axles without c-clips, these are the same length and have c-clips. is something wrong here too or is it just me?
Old Nov 30, 2001 | 11:15 AM
Z28DJP1987's Avatar
You have one big FURBALL. Sounds like nothing will work, LOL
Old Nov 30, 2001 | 12:21 PM
TexasLT1's Avatar
Car: '92 RS
are you serious? not even the axles???!!!! oh thats it, this guy is dead. I am not going to sit back and accept that I just wasted $200!!!!
Old Dec 3, 2001 | 06:42 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Your 10 bolt has equal length axles. Count the splines on those axles: There should be 28 splines on the axle if it is from a 1989-up application. Otherwise, if theres 26 splines, it is from the old 1982-1988 application.
You definitely have pre-1988 calipers in that photo. Those calipers present NO END of problems in terms of adjustability. Good luck! I ripped out my 1984 rear calipers and upgraded at considerable expense because of various problems, such as unacceptable pedal travel, non-functioning emergency brake, etcetera. Nature smiled on me and rusted up the bleeder screw enough for it to break off in 1989, and I took the opportunity to upgrade.
If you can get your money back, do it.
For additional hints, go ahead and check out these links:
http://www.isthq.com/~dan/1LEbrake.html
http://www.isthq.com/~dan/10bolt.html
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Dec 4, 2001 | 10:47 AM
TexasLT1's Avatar
Car: '92 RS
thanks, I feel better now that I know whats going on. I can't use them as I have a '92 with the 28 spline axles and those do in fact have the 26 spline. Im just going to try and resell them on e-bay as the correct parts, not as the '91 parts I thought I was buying.
Old Dec 4, 2001 | 07:05 PM
mckenzie's Avatar
i would tell the guy you want your money back for selling you the incorrect year calipers that were in the title. its hard to tell from pics. you were counting on him to supply you the correct info. his mistake. if he bows up on you, leave neg. feedback and see if e-bay will help you(let you post for free) best of luck, Tom
86 iroc 305tpi auto. mild cam
Old Dec 24, 2001 | 05:00 PM
IROC&ROLL's Avatar
Ebay has automatic $200 insurance on most all completed auctions, but there is a $25 deductible. So, if the guy doesn't make it right you can file a claim with eBay and get $175 back! Been there, done that. Good luck.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
rb85TA
26
Sep 14, 2015 10:29 PM
Numbah-1
Sep 12, 2015 08:57 PM
rudolphschenker
Sep 4, 2015 02:41 AM
