METCO drive shaft loop
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I just want to give a firm thumbs up to this piece. A little pricy, but it fit around my custom 3" driveshaft and Random Technologies Torque Arm without any problems.
For comparison, the Jegs one and the Lakewood would NOT fit.
1991 Formula, 406, miniram. Best run to date (9/30/01) 60' 1.63, ET 12.28, MPH 110.48
2002 Sunset Orange Metallic Z-28. Track time to come in Spring
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
It fit exactly as it was supposed to. All the angles were correct. The hardest part was pulling back the carpet to drill the holes in the floor.
They supply you with the nuts and bolts, but I opted to add a large diameter washer on the floor pan so if anything happened, it had a greater surface area to hold on to.
It was very simple and straight forward.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How much did it cost? Did it reduce you ground clearance any?
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
-Justin-
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I found www.JDSPerformace.com has them for 75. I've delt with this company for many things and 99% of the time they are the cheapest.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
