what steps are involved in replacing ball joints?
Old Dec 8, 2001 | 12:13 AM
breathment's Avatar
im not asking for specific steps, but something general so i know if i should try it this weekend with everything else im planning.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 8, 2001 | 03:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Jack it up, take the wheel off, put a jack under the control arm, remove the cotter pin and nut, separate the taper from the steering knuckle, press the ball joint out, press the new one in, insert the taper into the knuckle and torque the nut to spec, insert new cotter pin, grease it and lower the car.
Old Dec 8, 2001 | 12:19 PM
breathment's Avatar
do i have to remove the spring?
- David
Old Dec 8, 2001 | 01:10 PM
iroc5speed's Avatar
you don't have to remove the spring, just keep a jack under the control arm.
Old Dec 9, 2001 | 04:20 PM
Jza's Avatar
Jza
You should know that unless you have an on-car ball-joint press, or access to one, then you'll have to completely remove the control arm and take it to a shop to have the ball-joint pressed out and in.
Old Dec 10, 2001 | 08:06 AM
MD83Z's Avatar
I think you should check the control arm bushings at the same time. The ball joint gets grease (if maintained regularly) while the bushings don't. Your old post said a clunk when you apply brakes.Just my opinion.
Old Dec 10, 2001 | 09:39 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
The press is about $100 Bucks to purchase although you may beable to rent one.
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
