Installing drop spindles and want to change springs
Old Dec 10, 2001 | 01:15 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Since i have half the suspension apart anyway i thought i might as well change the springs. Is there any way to change them without using a spring compressor? I REALLY don't like them and would like to avoid using them. I will be installing new - same stiffness springs.
Old Dec 10, 2001 | 01:33 PM
82camaro's Avatar
Car: 82 camaro SC
With the spindle out, just drop the lower control arm down and let the spring come out. If you are worried about it popping out at you, put a chain on the spring. It shouldn't have much if any pressure left.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 10, 2001 | 01:43 PM
iroc5speed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
whoa there cowboy, those springs DO have a lot of pressure left. The way to do it without a compressor is to put a floor jack under the lower control arm and slowly lower the arm(after breaking the spindle free). It will probably get to a point where the spring is still sitting on the arm and the jack is all the way down. At this point the spring has minimal pressure, but still some. Just grab the spring and pull it loose, it shouldn't pop out at this point. I rebuilt my front suspension this summer and I can assure you that those springs have pressure the whole time they're on the LCA.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Dec 10, 2001 | 02:06 PM
Omega's Avatar
Engine: LS1 / LS3
Cool, thanks guys. If i end up with a spring up my nose i know who to blame Just kidding.
Old Dec 10, 2001 | 02:19 PM
FiReBReTHa's Avatar
omega, your gonna get us a pic of that right?
lol
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Dec 10, 2001 | 02:38 PM
Omega's Avatar
Engine: LS1 / LS3
But of course!!!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
