Steering Linkage bushings?
Old Dec 31, 2010 | 12:26 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
they are bushings right? cuz right now, when i touch them, it gets all over my hand so thats gotta mean they're bad right??
where can i find all the bushings for the steering linkage?
tie rods
centerlink
idler arm
pitman
Mikey
Old Dec 31, 2010 | 02:33 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Steering Linkage bushings?
What everyone does is just replace all these components with new ones such as ones MOOG offers for example. I've never heard of these components having bushings but I could be wrong.
Old Dec 31, 2010 | 02:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there are no bushings, they are all ball joints, they have no serviceable parts. Whats getting on your hands is grease. You are supposed to grease those things every now an again, they do have grease fittings on them.
If they are shot, you have to replace the entire parts.
the pitman is a non wear part, you only have to replace it if its broken damaged or missing
Old Jan 2, 2011 | 01:29 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
oh okay..i can twist the tie rods and they pivot from the rear side of the car to the front..is that bad? worn? i know my idler arm is bad and i ordered another one a couple days ago from moog..
Old Jan 2, 2011 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Your car is 20+ years old--and probably has hundreds of miles racked up. If steering components haven't been replaced along the way, you might consider doing them all in one fell swoop (and save yourself the expense of multiple alignments).
JamesC
Old Jan 2, 2011 | 11:35 AM
I agree. I did it all in one shot as well. Might as well as there's probably more than one part worn out. I heard that if there is any physical movement whatsoever in the steering linkage then something is worn out.
Old Jan 3, 2011 | 10:31 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
yeah, ima order the whole setup pretty soon thanks guys
Old Jan 3, 2011 | 01:38 PM
On a side note, since you don't need to replace the pitman arm since it is a non-wear item, you can always paint it black (that's what I did) to make it 'fit in' with your newer linkage pieces
Old Jan 3, 2011 | 02:55 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
haha..thats what i was thinking
and my sway bars
Old Jan 3, 2011 | 03:40 PM
JamesC's Avatar
and my sway bars
You might consider having the sway bars powder coated.
JamesC
Old Jan 5, 2011 | 03:06 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
any reason why in particular?
Old Jan 5, 2011 | 03:31 PM
JamesC's Avatar
Coating creates a hard finish that is tougher than conventional paint. Many after market parts, for example, are powder coated.
JamesC
Old Jan 5, 2011 | 03:49 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...is it expensive?
Old Jan 5, 2011 | 05:58 PM
JamesC's Avatar
I don't recall what mine cost. I'd imagine it depends on the shop.
JamesC
Old Jan 6, 2011 | 10:46 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
alright...ill call around thanks
Old Jan 6, 2011 | 11:20 AM
I used POR15 semi gloss black on everything i could get to underneath the car. It looks great and it forever protected! Lot of prep work tho (degrease, then metal ready to etch the metal, then spray or brush on).
Old Jan 6, 2011 | 11:28 AM
JamesC's Avatar
I used POR on the 85's a-arms and rear end several years ago. Still looks great. Get that stuff on you and you'll wear it a good long time!
JamesC
Old Jan 6, 2011 | 01:22 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...might do that.
Old Jan 6, 2011 | 02:04 PM
JamesC
How about 1 month of black dots all over ur face for a month at work?
Old Jan 6, 2011 | 03:09 PM
JamesC's Avatar
Yikes!
JamesC
Old Jan 6, 2011 | 03:20 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Not as bad as what happened to a guy applying "Herculiner" to his Ford Explorer...
Old Jan 6, 2011 | 03:30 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
"i herculined myself tooooooooooo myself"
Hotrodboba400
Dec 10, 2019 07:07 PM
camaro1185
Oct 26, 2015 06:51 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Fred SS
Oct 12, 2015 11:27 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
