Monroe or Gabrierl.
Old Dec 31, 2010 | 05:08 PM
Guest
Guest
Posts: n/a
Monroe or Gabrierl.
which one is better monroe sensa trac monroe matics? or Gabrierl plain or gabrierl ultra. Would like opinion this is going on the back of my car i only am replacing back two shocks.
Thanks need some of your answers and the way they ride. I'm not looking for a race setup.
Old Jan 1, 2011 | 11:44 PM
3rdgenfever's Avatar
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
Re: Monroe or Gabrierl.
monroe sensa tracs are a good product, gabriels are just cheap junk.
Old Jan 2, 2011 | 10:02 AM
Gus_Mahn's Avatar
I don't know about the ride, but in my experience Monroe is better by a noticeable margin than Gabriel.
Old Jan 2, 2011 | 10:05 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i would say the monroe over gabriel, but both are nothing to be impressed with.
Old Jan 2, 2011 | 10:15 AM
Guest
Guest
Posts: n/a
Ok I'll get the monroe and everytime i look at my back shocks though as it's sitting in the garge it's getting lower and lower. I should really have it jacked up.
Old Jan 2, 2011 | 10:20 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
shocks have NOTHING to do with the ride height, they just control the springs movement
Old Jan 2, 2011 | 11:32 AM
AmorgetRS's Avatar
This should be in the suspension section.
IMHO, neither.
Old Jan 2, 2011 | 03:54 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
It depends on the shock and how bumpy the road is. Regular shocks aka heavy duty shocks only pull the car down. Gas shocks will cause the car to be higher on bumpy roads. After I drive my car when I get out it sits about 2" higher until the shocks bleed down.
To the topic.
Here is what I have on my car and to work great. I have a stock drivetrain. I don't have any problem with under or oversteer. I like the ride and when needed to holds to the road when cornering.
http://www.autozone.com/autozone/par...586_6880_1759_
http://www.autozone.com/autozone/par...861_6880_7413_
Old Jan 2, 2011 | 07:04 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
while i'd say monroe if left with those choices, I'd honestly recommend spending an extra $20 or so and get a pair of KYB gr2 or gas adjusts. very close to the price of the others and much better liked by all.
Old Jan 2, 2011 | 07:37 PM
torque_is_good's Avatar
either will be better than what the vehicle had when it left the factory.
You can always spend more money and get upgraded performance units.
zee28
Sep 5, 2009 08:16 PM
1986sc
Sep 1, 2003 06:45 PM
1986sc
Aug 30, 2003 03:14 PM
330hp_91RS
Mar 14, 2003 07:10 PM
toosloz
Dec 21, 2001 03:52 AM
