Ball joint spinning, how/why is this happening???
Old Jan 1, 2011 | 04:30 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
So I am trying to swap my front springs so I took the wheel off and started compressing the spring. I then put a jack under the a-arm and started to jack it up. After that I attempted to remove the castle nut, as I did so, the ball joint and but started to spin togeather... So I have no way of getting the spring out now since I can't take the ball joint appart.
The car has no motor right now and it is up on jack stands.
Please help.
Old Jan 1, 2011 | 04:49 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: Ball joint spinning, how/why is this happening???
Take off the spring compressor and try to loosen (but DO NOT remove) the ball joint castle nut. The added pressure from the spring should keep the ball joint from spinning. If that doesn't work, use an impact gun.
Old Jan 1, 2011 | 04:56 PM
Drew's Avatar
Or put your jack under the control arm/joint and jack up on it to force the tapered ball joint shaft into the spindle.
Old Jan 1, 2011 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
or if all else fails, use a large c-clamp to pull the spindle down onto the balljoint and make it tighter. Or an impact gun should make short work of it.
Old Jan 4, 2011 | 06:52 AM
Engine: LS3
I uncompressed the spring and the castle nut came right off with a wrench. Thanks guys.
Now I am welding reinforcments to my PA Racing A-arms and K-Member! Without the tips I would have been dead in the water all last weekend.
Old Jan 5, 2011 | 05:24 PM
Pocket's Avatar
Car: 91 Trans Am
Glad you got it off without incident
For those not so lucky, this tool is a last resort
http://www.harborfreight.com/7-8-eig...ter-66419.html
Do not try cutting the balljoint stuff with a saw. It is hardened extensively
Ed1LE
Sep 30, 2018 09:14 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
