Lowered I need traction again what all should I buy?
Old Jan 10, 2011 | 09:06 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
Axle/Gears: 2.73 , 3.42 soon
I lowered my car with the dropzone springs and ended up cut the rear springs a coil more to get it where I want anyways traction sucks now I'm getting the lca relocation brackets is that all I need or is there more that I can do to give my car more traction thanks
Old Jan 10, 2011 | 09:30 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Lowered I need traction again what all should I buy?
start with the relocation brackets, then get some sticky tires, if your nose doesn't pop up not much you can do
Old Jan 12, 2011 | 12:19 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
you have a 305 tbi with 2:73's and bad traction, uhmm i take it this is an open rear end
Old Jan 13, 2011 | 09:32 PM
adm030's Avatar
Car: 92 camaro rs
Engine: lo3 305 tbi
yep I had ok traction before and now i get to about 4000 rpm and they break loose first gear is really the only problem i have a posi trac rearend that's getting installed but i have 3.42's with it so thats only going 2 make it worse or I would think that anyways I'm getting the relocation brackets i just was wondering if the lcas and panhard bar would help or not really thanks for your help
Old Jan 13, 2011 | 10:41 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
posi is actually only good for about a 10% traction increase...
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
