Jacked up
Car: 1982 Camaro Z28
Engine: 350 small block
Jacked up
My 82 camaro has a problem, i was just wondering why the body is not sitting on the tires and theres a big space between the fender wells and tires??
Car: 87 GTA
Re: Jacked up
Post a pic. It sounds like it is at stock ride height, the way it came from GM.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Jacked up
the body doesnt sit of the tires, there is a gap there. 3" or so is about stock, maybe even more, thats normal. If you want less, you need to lower the car using various methods.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Jacked up
I have between 3" and 4" on my car (depends on which wheel).. Measure the gap for us to let us know. Also, did you change your springs recently? If so there might be an issue there.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Jacked up
yea, the body should not "sit" on the tires. if this was the case you would blow through tires in a few miles and the car wouldnt even move. there has to be a gap...to allow for suspension travel when u hit a bump etc. not a gap like a monster truck, but a few inches.. as stated above
Car: 87 GTA
Re: Jacked up
My body sits right at the tire top, but I never rub the inner fender nor the fender itself.
roysatikas
Sep 22, 2015 08:15 PM
