What Can A Posi Picture Tell You?
Car: Black 82-92 Firebird
Engine: 383 Strokey
Hey ThirdGen,
I just started floating around on Craigslist for a rear unit. What can you tell me about this picture?
A decent price in your honest opinion?
I called dude up and took some notes, I'm a n00b though and didn't wanna sound like a terd asking him questions. He claims this cost $500+ on summit.com, does that sound foreal foreal?
Please help me decipher this :
LIMITED SLIP CENTER - change gear ratio, 373 - good gear for highway.
++ MISC NOTES ++
limited slip - posi track, stock gear ratio. Ring pinion and only thing to purchase is the bushings, crush collar. After market setup
- take differntial cover off
- two carrier bearings
- take cap off and put assembly together
- shims an all together.
++ MISC NOTES ++
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: What Can A Posi Picture Tell You?
I had gotten a whole rearend for about $150 he needed headers I needed rearend so we traded I payed $150 for the headers. For a new carrier from gm just like the carrier you have pictured its about $900 to $950 I was given a link that helped me out alot on installing this https://www.thirdgen.org/forums/tran...axle-gear.html
Engine: Tpi 5.7
Axle/Gears: 3:23
I would put new carrier bearings in and do everything that link says to do
That's an Auburn, looks like a stock one; 2-series it appears, although it's hard to tell, because I can't see the back side of the ring gear flange well enough to be sure. But, being as how the pinion has 15 teeth, it's probably a 2.73 (15 and 41).
THe highest numerical ratio you can put on it without using the "special" gears, is 3.08.
You can buy a better one (to the extent the word "better" can be applied to an Auburn... maybe, "not as crappy" would be more accurate) from Summit for about $400 some-odd. One for a decent gear, same price.
I wouldn't pay a dime for it. Last Auburn I accidentally got somehow, I gave away; and it was a high-perf one (had more clutch springs than that stock one), and 3-series besides. Worth exactly ZERO to me. That one is worth even less. I guess you'd have to pay me to take it.
Keep looking.
Keep looking.
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
3.73 = NOT good for Highway Gears
2.73 = VERY good for Highway Gears
3.73 = VERY good for Launches on a Street Car
2.73 = NOT good for Launches on a Street Car
Engine: 383 Strokey
Thanks for the quality responses - the provided info will enable me to make a great decision when time to purchase....as for this unit, I think I'll pass and wait for another rear.
Of course, if you have more information, I'll be sure to bookmark it.
Thanks again for your time.
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
