Spohn frame connectors
Old Feb 9, 2011 | 07:47 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Has anyone used Spohn frame ties for a convertible. I'm being told they are expensive to install...anyone expierenced with them or others? My goal is to snug the car up a little and keep rattles to a minimum....only stock powertrain,,,
Old Feb 17, 2011 | 11:40 AM
89redliningRS's Avatar
Re: Spohn frame connectors
I bought the weld in connectors for my ttop car. I welded them in myself. They are not to bad to do. I just pulled the carpet back where I was welding and sanded a bare spot where I was welding. I believe you need to keep the wheels on and put the car on top of wheel stands to keep it level. If you find someone that can weld then your only looking at an afternoon to do it.
Old Feb 23, 2011 | 09:40 AM
CHJ37's Avatar
Car: 1991 Chevy Camaro
Engine: Chevy 305 bored .30 over
89 redlining RS,
did you weld them inside or outside the car?
Old Feb 23, 2011 | 10:09 AM
They are welded on the outside, but you are welding them to the floor pan. So if you get the floor hot enough you may have a carpet fire. You just need to pull the edge back, I didn't even take out the seats. So it's only about 4 inches of carpet.
Old Feb 23, 2011 | 08:43 PM
CHJ37's Avatar
Old Feb 23, 2011 | 09:26 PM
Sandslot's Avatar
Engine: LB9
Did you purchase the powder coated or bare metal? How and what prep did you do?
Old Mar 1, 2011 | 01:29 PM
I went with the powder coated. Just sand a bare spot on the connector where you want to weld it and wipe down the underside of the body and your set. After welding I went back and sprayed the welds with some cheap spray can paint that was a close match.
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Lanz06
Sep 14, 2015 07:16 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Nick McCardle
Sep 10, 2015 08:36 PM
