Help needed w/ J&M poly ball LCA's
Old Feb 20, 2011 | 05:35 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
I need some help from someone that has installed the J&M poly ball lca's on their car.
First i had a hell of a time getting the poly ball into the lca, then after pushing in the caps/outside pieces, they pop back out as though air is trapped inside.
I can't get the caps to stay in far enough to even begin to mount these.
Any help or advice is greatly appreciated!
Thanks ..
Old Feb 20, 2011 | 08:16 PM
hotpart's Avatar
Re: Help needed w/ J&M poly ball LCA's
Thanks ..
Push the outer cups into the arm without the center sleeve in place. This will allow the air to escape.
Old Feb 20, 2011 | 09:18 PM
Rons91Bird's Avatar
Great , thanks, that works!
Old Feb 20, 2011 | 11:26 PM
Guest
Guest
Posts: n/a
Talk about quick customer service response....
I would not have known that answer.
Old Feb 21, 2011 | 12:09 AM
Rons91Bird's Avatar
Now i'm wondering if the J&M decals are supposed to face inside or outside? or does it matter?
Old Feb 21, 2011 | 10:55 AM
hotpart's Avatar
It doesn't matter.
Old Feb 21, 2011 | 11:06 AM
Rons91Bird's Avatar
It doesn't matter.
Thanks Hotpart!
J-money
Jan 4, 2019 09:45 AM
88CamZ
Oct 8, 2015 10:29 AM
Jorlain
Oct 8, 2015 01:57 AM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 10, 2015 10:41 AM
