Lowered the bird an inch...
Old Feb 23, 2011 | 02:01 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I was on lunch break today and started doing some reading on third gen. Came across the "lowering 101" thread and realized that I had my car lowered an inch and saw that I should install the adjustable panhard bar, LCA relocation brackets, and an adjustable torque arm.
Is this important if I only put in the eibach pro kit? (1") I haven't really noticed and unusual tire wear or ride.
Old Feb 23, 2011 | 02:33 PM
87350IROC's Avatar
Car: 87' IROC
Re: Lowered the bird an inch...
For a casual cruiser I wouldn't worry about it.
Old Feb 23, 2011 | 09:12 PM
Mr Froman's Avatar
It's my daily driver. Like I said, no unusual tire wear or anything. I had it on a lift the other week and figured I'd spin the tires and check for anything out of the ordinary. Lowered it a little over a year ago.
Old Mar 7, 2011 | 02:06 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
should be fine..would suggest an alignment tho
Old Mar 7, 2011 | 02:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Might need the adj panhard bar - a 1" drop can move the axle towards the pass side some - just have to look and see if your pass tire sticks out farther than you driver side. No need for toque arm or LCA's. Other than that, there's nothing in the rear to get aligned. If all you did was springs without changing tie rod ends or centerlink, no need for an alignment. But like you said, no bad tire wear so your golden.
Old Mar 7, 2011 | 02:46 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
For a lowered car I would suggest adjustable shocks, rear adj.LCAs/brackets, adj.PHB, and alignment. That is, of course, if your doing things correctly. You may not feel you need the control arms, but once you get some really nasty wheelhop you may change your mind
Old Mar 7, 2011 | 03:46 PM
Car: 1992 RS
Engine: Carbed 350
Yeah, I prefer to keep my rubber on my rims rather than on the pavement, so no wheelhop here. Some see tire spinning as fun, I see it as a waste of power and a loss of the race. Now on a strip car that's a whole different story. But redlight to redlight makes no difference on a mild engine car.
87v6Bird
Jul 1, 2018 04:12 PM
Magman
Aug 2, 2016 08:32 PM
jbates346
Oct 21, 2015 01:50 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
