spohn k member install question
Old Mar 16, 2011 | 01:48 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well a while back I bought a tubular k member. And ill be installing it soon but was curious do I need some alignment pins? If so where do you find them generally? Also is there anything else I should know before installing it. Motor is already out.
Old Mar 16, 2011 | 02:04 PM
87350IROC's Avatar
Car: 87' IROC
Re: spohn k member install question
The k-member should already have alignment pins on it.
Old Mar 16, 2011 | 04:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
then its just 6 bolts. Dont forget to unbolt the brake lines before you drop the old k-member
Old Mar 16, 2011 | 04:37 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well I already dropped the old one out.
Old Mar 16, 2011 | 08:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well then you are half way there. should install just as the old one did.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
SiCkRs
Aug 8, 2015 08:12 AM
