clacking in front end
Old Mar 31, 2011 | 04:07 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
when im driving my car in town from 10 to like 35 mph and there is a clacking noise coming from the front driver side. when i hit the breaks the noise stops so i thought it would b something to do with the caliper or pads but nothing was loose so im not sure where the noise is coming from. any advice would help thanks
Old Apr 1, 2011 | 12:07 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: clacking in front end
sounds like a caliper, not sure though.
Old Jul 10, 2011 | 02:22 PM
oldguy's Avatar
Car: 1991 z28 Coupe
Engine: 305 LB9
Transmission: 5 SPD MAN
Axle/Gears: 3:42 G92
I am experiencing the same problem on my front driver side. I have the performance 1Le brakes, the caliper is slightly loose and makes a clacking noise at low speeds untill you brake. The caliper is held in place by only 1 pin, not sure how to remove the caliper play. Would appreciate some advice .
Old Jul 10, 2011 | 05:00 PM
Sounds like the bushings the caliper rides on.
If you have the non-1LE brakes, the calipers are less than $10 apiece. When in doubt, swap em out. Your time is worth more than that. Just do it and move on.
Old Jul 10, 2011 | 11:59 PM
oldguy's Avatar
Car: 1991 z28 Coupe
Engine: 305 LB9
Thanks I will look into that,, mine are 1LE brakes, are there bushings there as well ? I did not notice any when I took the caliper off
Old Jul 11, 2011 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No bushing that I recall for the 1LE. You might check the adapter to spindle bolts as well as the carrier to adapter bolts. Perhaps something has worked loose.
JamesC
Old Jul 12, 2011 | 01:10 AM
oldguy's Avatar
Car: 1991 z28 Coupe
Engine: 305 LB9
Thanks , I replaced the pads which helped a bit, still getting some noise, will try replacing the caliper pins
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
