shocks
Old Apr 3, 2011 | 11:16 PM
wheel.man's Avatar
Car: 91' z28
Engine: 5.7 tpi
Transmission: auto
shocks
Alright guys I jus recently purchased a 91 z28 5.7 tpi....and the guy I bought it form put a airbag suspension,with switches and everything I have no idea y.......but I want it off ASAP and I want to kno wut all do I have to put bak on....can any1 help me out
Old Apr 4, 2011 | 06:12 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: shocks
as long as none of the mounts were modified, swapping everything out should be quick and painless. The springs and struts/shocks are separate on both the front and the rear and have their own mounting points. I take it you only have bags in there now and no springs?
Old Apr 4, 2011 | 08:09 AM
wheel.man's Avatar
Car: 91' z28
Engine: 5.7 tpi
Transmission: auto
Re: shocks
Yes correct there are no springs.....actually I dnt think there is even the struts are there jus the bags
Old Apr 4, 2011 | 08:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: shocks
if its just bags, you'll need to grab new struts, shocks, and springs. if you're looking to stick with stock height, moogs tend to be the coil of choice, eibachs being the lowering spring for most. if you're on a budget, KYB GR2's are a good stock type shock/strut; koni's and bilstein are the more primo choices (but can break the bank for some)
Old Apr 4, 2011 | 07:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: shocks
the front air ride setups put a air bag in the spring perch, so there is still a stock strut in there. without it, then wheel would pretty much fall off.
Old Apr 10, 2011 | 07:30 PM
wheel.man's Avatar
Car: 91' z28
Engine: 5.7 tpi
Transmission: auto
Re: shocks
Thnx for the info guys...but wut goes in the front and wut goes in the front
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
