A ARM BUSHINGS
Old Apr 16, 2011 | 03:25 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
A ARM BUSHINGS
i have changed everything on my from the rear traling arms /panhard bar and front and rear end links with polyeurethane ones..new coils and and strut ,shocks etc etc...the only thing i was wondering about were the front lower a arms..the bushings on these things look old..anyone change these?..or do they sell affordable a arms with bushings and ball joint already there?
Old Apr 16, 2011 | 03:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: A ARM BUSHINGS
options are to replace bushings and ball joint in your current arms, or get another setup of used stock arms, swap new parts on them at you leisure, then swap the entire arm,
or aftermarket tubular ones.
thats pretty much it.
Old Apr 16, 2011 | 04:33 PM
mooch1's Avatar
Transmission: T5 WC
Re: A ARM BUSHINGS
that makes sense, i saw some tubular ones and they are real expensive..i think i will evetually replace the bushings and ball joints on mine ...thanks.
Old Apr 16, 2011 | 06:07 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: A ARM BUSHINGS
i jsut grabbed some energy suspension bushings and moog ball joint replacements for mine. stock a-arms are pretty heavy duty as is, just give em a refresh and you should be good to go.
Ed1LE
Sep 30, 2018 09:14 AM
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
