Broken torque arm?
Old Apr 27, 2011 | 08:26 AM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Broken torque arm?
I know this is stupid to ask, but I didn't have time to look under the car after I got her home last night, and now I am at work contemplating. I was starting from a light and let out the clutch a bit fast and I heard a loud metal on metal grinding/clunk come from the rear of the car, followed by sloppy shift action into second and third. The metal on metal sound persisted for about 15 seconds as I was pulling over (sounded like something was dragging) but i didn't see anything hanging when I looked under the car in the dark. I started the car up again and was greeted with a ton of vibration through the driveline... I got in and drove her home, with very sloppy shift action persisting and a clunk from the rear of the car under to much load. I replaced my stock trans mount with a urethane mount about a month ago, so I figured the stock torque arm could be my weakest link?
Old Apr 27, 2011 | 09:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Broken torque arm?
Not likely, think farther back.
Old Apr 27, 2011 | 11:27 AM
68Strat's Avatar
Engine: 360
Well if it is the rear end, it's a good time to upgrade anyway.
Old Apr 28, 2011 | 07:18 PM
68Strat's Avatar
Engine: 360
Just crawled out from under the car. The torque arm came unbolted from the tranny and lodged itself near my shift linkage! Hopefully once I pull it out it will just bolt right back on.
Old Apr 28, 2011 | 08:53 PM
68Strat's Avatar
Engine: 360
Torque arm re-mounted and the car drives mint again!
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
