Tinny rattling from rear
Old Apr 27, 2011 | 04:46 PM
Alinton's Avatar
Car: '87 Camaro
Transmission: 5-speed manual
Hey, when driving on rough surfaces etc, I'm hearing a tinny rattling sound from the rear.
Not clunking, it sounds a bit like alloy-type metal rattling.
I had a quick look underneath this evening and the sway-bar bushes look ok;
Any ideas what this could be please?
Andy
Kilkenny,
Ireland
'87 Camaro IROC-Z.
Old Apr 27, 2011 | 05:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tinny rattling from rear
look at the rear heat sheilds over the muffler and over the exhaust pipe where it goes behind the back seat and over the axle. if they have come loose, they can rattle and they will sounds tinny. Those two pieces actually fit together just behind the axle before the upper panhard support, if they popped apart, again, you will get noise form them rattling against each other.
or maybe its all something exhaust related, a loose baffle in the muffler or something,
Old Apr 27, 2011 | 06:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Also check the dust shields on rear disc brakes if you have them.
Old Apr 27, 2011 | 06:44 PM
RedneckNo4's Avatar
Car: Trans am
Engine: 78 350
Axle/Gears: 9 bolt 3.27
is it worse in D than in park? my muffler/gas tank heat shield rattles when i'm at a stop in D but never when i'm in park or moving
Old Apr 28, 2011 | 03:26 AM
Alinton's Avatar
Car: '87 Camaro
Its a manual, but no it only happens when moving over rough ground, lumpy road surface etc.
Thanks for the heatshield suggestions, I'll have a look at that. It doesn't sound like the muffler.
Andy
Old Apr 29, 2011 | 12:17 PM
Alinton's Avatar
Car: '87 Camaro
It was the inner brake pad on the driver's side rear that was rattling.
I'm hoping a blob of silicone will have fixed it!
Is there supposed to be a clip or something?
Andy
hectre13
Dec 11, 2023 08:14 AM
xxx3man`
Sep 23, 2015 10:37 PM
aaron7
Aug 26, 2015 09:45 AM
mustangman65_79
Aug 8, 2015 12:07 PM
