What kind of Springs/Struts and Control Arm can I use for a 82 T/A ?
Car: 89 Trans Am
Engine: 5.0
Hey guys ! Hope all is well. I have my 82 Trans Am, which I am in the process of swapping out the Crossfire engine to a 350 Goodwrench. And I would like to change the Front Springs/Struts and Control Arm on my car. I'm looking for stock height and I'm looking for a Front End Kit also.
Any help would be great Thanks
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: What kind of Springs/Struts and Control Arm can I use for a 82 T/A ?
Don't get spohn a arms, they move the wheel back... redoing the stock a arms is your best bet, you can get new ball joints, and upgrade the bushings to poly or delrum via global west. May need stiffer springs for a 350...
Car: 1987 Trans Am
Engine: LQ9/L92
springs - if you're looking to stay stock, moog is the way to go; eibach if you want to lower things down a bit
control arms - if you're referring to the front, stick with stock and get yourself some new bushings and ball joints; these pieces are pretty beefy and really don't need replacing
struts - kyb gr2 is a good economical setup, koni or bilstein if you've got the money for something good
fill the rest of the front end with moog and energy suspension parts and you'll be set for years to come
Go to the junkyard and get another set of control arms, and put your new BJs and bushings in those. Makes the whole car tear-down/re-assy MUCH quicker and easier. They're SUPER common and CHEEP; apparently some other chassis uses the same ones, maybe S trucks or G bodies or something, I don't know what, but whatever it is, there's ALOT of em.
Nothing about any of that is specific to 82. Anything that fits any thirdgen fits it.
Just a note (I know enough to be dangerous!
There is some difference between 82, 83 mid year and later up to 92 A arms...
The Global West Sites has 2 different Delrum bushing kits because of it...
What the difference is, I don't know... but having a spare set to get done up and just switch them out is a great idea.
)There is some difference between 82, 83 mid year and later up to 92 A arms...
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Or, go to the junkyard and get another set of arms, and put your new bushings in those instead, to make the down time shorter.
All bushings may not interchange in all arms; but all arms interchange in all cars.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just a general FYI: The steering stops are different between 15" and 16" wheels. The bump stops are different as well:
Bumper, Lwr Cont Arm (1982-84) (1985-87 Exc FEZ) (1988-91 W/15" Whl) P/N 10068783
Bumper, Lwr Cont Arm (1985-87 W/FEZ) (1988-91 W/16" Whl) P/N 14089443
Both the above are available from the following site:
http://www.moderndaymuscle.com/under...x=172&start=40
OE replacements, at least the 15's, can be had from RockAuto and other sources. Interestingly enough, alternative part numbers for Dorman 31061 show both 10068783 AND 14089443. The Moog version (K6606), which measures 2" high, can be had at Advance Auto for $8.99 per.
After thought: Since ovaling of the end link hole is common in a-arms, you might try to find junk yard arms that haven't been affected.
JamesC
JamesC
Car: 89 Trans Am
Engine: 5.0
Hey Luvojah ! The A-arms,I'll just redo them,thanks bud.
Hi 1ADan ! Springs,Moog sounds good.And I'll go with the Kr2 Struts and Shocks and do over the front end in Moog,thanks
Sofaking, I might just keep the current control arm on mine, there is nothing wrong with it,I was thinking if I should change it because it is from 1982,but I guess I'll just redo the front end.
RK , great idea about measuring the bushings,I will certainly do that
James,thanks my friend, I went to the site and purchased the stops.
Other upgrades that made a difference for me... stock height too (got moog springs)..
Aftermarket rear lower control arms (non adjustable since stock height) and panhard bar too... Spohn Sub Frame connectors tuck and roll nicely under the frame... wonder / steering brace / bar, strut tower... and new poly bushings throughout.... I did get the spohn steering kit too... all good, just not their a arms...
Raf
Raf
Car: 89 Trans Am
Engine: 5.0
Hey Luvojah ! I picked up the Moog Springs for the Front and Kr2 Struts
Hopefully I'll get the Spohn Steering Kit next week,thanks bud
Hopefully I'll get the Spohn Steering Kit next week,thanks bud Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
