Power Steering Lines
Old May 3, 2011 | 08:17 AM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Has anyone made or done braided stainless steel lines for the power steering lines? Russel Performance sells lines and fittings, they say they hold 2500 psi, but not sure about putting them together. Any thoughts/recommendations, and fitting sizes for the stock GM box..
Mike
Old May 3, 2011 | 06:49 PM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Re: Power Steering Lines
I made braided lines using the russel hose and fittings for my 2nd gen AGR box. It was awhile ago but dont remeber it to be too hard and I have no special tools. Used the ANC adapter fittings they sell too never had a leak.
Old May 3, 2011 | 07:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
forget Russle fittings, they SUCK!!!! every one i put together for my PS setup leaked.
Fragola (spl?) makes precrimped teflon high pressure lines, summit and jegs sell them. I used them after giving up on the russle fittings. The Fragola stuff worked very well, and they dont leak!
box fittings are 16 and 18mm x 1.5 o-ring seal fittings.
Old May 4, 2011 | 06:48 AM
Realmac4's Avatar
Did you assemble them yourself or have someone do it?
Old May 4, 2011 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
which lines? the fragola's are pre assembled lines, so i just installed them. and i did assemble the russel lines myself. they are the ONLY lines i have EVER assembled that have leaked.
Old May 9, 2011 | 02:46 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
if you like the look of braided ss then get some made up.
most of the do it your self stuff they sell is only good to 3 / 400 psi.
the stuff you can get made for you is good up to 2000psi
you can get chrome ends and all the bling bling ya want
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
mdtoren
Aug 23, 2015 12:52 PM
