i AM new here strande suspention steering problem
Old May 5, 2011 | 07:40 PM
gsx1's Avatar
Car: 72 BUICK GSX & 89 FIREBIRD FORMULA
Engine: 455 GSX 305 FORMULA
i PICKED UP MY KID A 89 FORMULA , NICE CAR BUT THE STRANGEST STEERING PROBLEM I HAVE EVER SEEN ON A CAR . STEERING IS TIGHT STIFF SUSPENTION ALL NEW STRUTS AND SHOCKS ADDED A FRONT WONDERBAR CAR STILL WONDERS WILL FEEL GOOD THEN YOU HAVE TO START TO CHACE IT SOME TIMES VERY LITTLE WHEEL MOVEMENT WILL CORRECT IT OTHERS REQUIRE MORE AND ONCE ITS STREIGHTENS OUT IT WILL SEEM FINE FOR A SHORT DISTANCE hAS ALL NEW TIRES AND A ALGNMENT DONE hELP ANY ONY
ALMOST FEELE LIKE THE FRONT END IS MOVEING UNDER THE CAR , i HAVE CHECKED IT OUT AND FOUND NOTHING ??
Old May 5, 2011 | 09:38 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: i AM new here strande suspention steering problem
steering gearbox loose? Deffinately have something wrong. Your alignment guy should have found a problem. A good alignment guy would have. And just because it is in factory specs. does not mean it is aligned properly. These cars basically require a total custom alignment. In my eyes all cars need a custom alignment. But i'd take it to a known reputable front end shop and have them inspect it.
Old May 9, 2011 | 07:09 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
i had the same problem, and i took it back to the alignment shop again, and it fixed it quite a bit, but not perfect. And ive heard of people having to take their thirdgens back several times for re-alignment. If not that, check for loose bolts. i jacked up the front of the car and moved it back and forth and checked for play underneath. Id start with that
Old May 10, 2011 | 02:53 AM
gsx1's Avatar
Have checked again found some play in drag link will replace found nothing loose I am narowing it down every thing i fix gets a little better OH and also found Hardpan bushings shot , That i Know will give a weird drive
backtothe80s
Sep 5, 2015 12:39 AM
overdriv
Aug 20, 2015 03:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
