Car pulls while braking..
Old May 19, 2011 | 04:55 AM
VelocitySc0pez's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 TBI
I bought a used 91 Camaro RS 305 tbi, and when i brake the car pulls hard to the left side. what I do is countersteer, and its not an issue unless im going 50+ and trying to stop quick. It most likely isnt a big enough deal to cause an accident. but what should I look at? Tierods? steering column?
Im also on a small budget. please help, thanks.
EDIT: the car drives straight when you let go of the wheel but sometimes pulls to the right
Old May 19, 2011 | 06:20 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Car pulls while braking..
Alignment is probably o.k. Some roads pull depending on the slope of the crown.
Your problem is in the brakes. Most likely a seized piston or slider bushings on the right side that's preventing the caliper from grabbing the pads properly.
Old May 19, 2011 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An issue common to your description is a failing brake line.
JamesC
Old May 19, 2011 | 07:04 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree. I had same issue on mine. It would literally try to pull me out of my lane when I hit the brakes hard. Few months went by and the hose collapsed to the driver front caliper locking it up (tire squealing while I was driving in town).
Replaced with some nice Earl's SS Braided Lines and never looked back.
Old May 20, 2011 | 05:19 PM
Car: 1991 Camaro RS
Engine: 305 V8 TBI
how much did replacing lines cost you?
also, if the issue is within the brake caliper or rotors i will be doing a full brake rebuild after a few paychecks so we should be good
Old May 20, 2011 | 05:51 PM
karl's-92'-z28's Avatar
Car: Too many cars
Brake hose not the solid lines is what they mean, stock replacement brakes hose runs about $18-$20 for 1 side. The stainless steal hoses will run a bit more. I say replace both hoses & you will be good to go, youll prolly spend $50 thats including a bottle of brake fluid.
Old May 20, 2011 | 06:03 PM
Engine: 383 SBC
SS hose kits depends on your brake configuration. I had front NON-1LE and rear disc so it was a 5 piece kit (2 front, 1 rear to distribution block on the rear, and 2 rears). You can find prices from Summit. I think mine was around $80 when I purchased it ~8-9 years back.
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
