Can I mix SUPER LUBE with regular grease?
Old Jun 10, 2011 | 11:42 AM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
I have acouple of tubes of SUPER LUBE.
I've had my car for a year and I don't know what kind of grease was used(natural or synthetic). My question is would synthetic grease mixed with natural grease from prior lube jobs cause a problem?
Old Jun 11, 2011 | 06:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Can I mix SUPER LUBE with regular grease?
No. If you wish, you can over-lube with synthetic and push the old grease out.
JamesC
Old Jun 11, 2011 | 09:47 AM
karl's-92'-z28's Avatar
Car: Too many cars
I wouldnt mix bearing grease. Its like mixing regular & synthetic motor oil.
Old Jun 11, 2011 | 12:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In that case mixing bearing grease is just fine.
Old Jun 12, 2011 | 11:45 AM
Car: Too many cars
Good to know, i have always cleaned all the old grease off to inspect the bearings, well it helps if you have access to a solvent tank also as do i?
MrPackstin
Oct 25, 2017 08:09 PM
no green
Jan 9, 2016 09:22 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rusty vango
Sep 29, 2015 02:44 PM
Dragonsys
Sep 25, 2015 03:51 PM
