94 Grand Prix rear suspension seems frozen
Old Jun 27, 2011 | 12:15 PM
mikeynoclue's Avatar
Car: 85 Chevy Camaro
Engine: 2.8 L V6
Sorry I posted similar post in General Tech...
I've read through this site in the past and saw great responses to help issues, so was hoping you could help me out. MY brother owns an 85 Camaro, that is how I found this site.
My 94 Grand Prix rear suspension seems to be completely frozen. There is no flex(maybe 1/4 to 1/2 in if you push down really hard), just very stiff. I'm assuming that both rear struts need changing, but it seems odd that both would go at the same time. The rear suspension got bad after driving through a really bad rain storm.
The person at the local autoparts' store mentioned that it could be the horizontal spring going bad. If so, is there a way to check?? or am I over thinking this too much and should just change the struts.
The car has 212K, but rr struts were changes approx 120K ago. I'm looking to fix the car today after work, I'm tired of bouncing all over the place when I hit a bump
thx for the help
Old Jun 27, 2011 | 01:50 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: 94 Grand Prix rear suspension seems frozen
http://www.grandprixforums.net/
I'm a member there. It's a great forum, someone can help you.
But to offer some input, You really shouldn't be able to compress them a considerable amount, or at least none of my cars ever have...
Old Jun 30, 2011 | 10:49 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm surprised this hasn't been locked yet...
Anyways, if the water was rather deep, you may have gotten some in the rear shocks and that's what's making the rear end to stiff. I doubt that the water had any affect on the leaf spring (don't you just love how cheap GM got with the W-body for that short time?) or the sway bar/shock bushings. Keep in mind the shocks are hydraulic and are filled a to a certain capacity with oil. Any liquid that could get inside them (past worn seals, rust holes, etc) will make them a lot stiffer.
Probably time for new shocks and struts.
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
Randomtask2
Aug 13, 2015 01:57 AM
