88 Iroc 0 movement front suspension
Old Jul 6, 2011 | 12:16 PM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
I just purchased an 88 Iroc. The front suspension has zero movement. If you jack up the front it slowly drops (sticking sometimes) making scraping noises. I can't see anything rubbing. Once the front has dropped all the way and you put it back on the ground it has a lot of movement (very bouncey). Drive the car just a few feet its zero movement again. It's not resting on the bump stops. I have at least 2" of space between the bump stops and frame. Front struts bad? I was thinking maybe springs cut but I can't see the ends with out removing them.
Old Jul 6, 2011 | 04:08 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: 88 Iroc 0 movement front suspension
The struts are shot.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
cam-mike
Aug 24, 2015 07:23 AM
mustangman65_79
Aug 11, 2015 03:17 PM
