Spohn Kmemeber w/stock A-arms
Old Jul 7, 2011 | 07:47 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Mocked up my Kmember, and wanted some opinions on how my wheel gaps look? These things seem to be a hit or miss with fitment, and installation. Luckily for me installation was a snap, and I think the wheel gap looks alright.
Setup includes; Spohn LSx Swap Kmember, Stock A-arm, Modified Stock Spindle, Kore3 Z06 Caliper, and Koni Yellows.
Attached Thumbnails Spohn Kmemeber w/stock A-arms-img_2639.jpg   Spohn Kmemeber w/stock A-arms-img_2636.jpg   Spohn Kmemeber w/stock A-arms-img_2633.jpg
Old Jul 7, 2011 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn Kmemeber w/stock A-arms
couple of the pics look liek the wheel is back a little, but keep in mind, the wheel will move more rearward as you compress the suspension, so jack up the arm if you can and see what happens then
Old Jul 7, 2011 | 09:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
All I can say is good luck! I had the Spohn k member and A arms and my wheels were set back once lowered. I sold the spohn A arms, went with the UMI arms and my wheels are centered again.
Old Jul 7, 2011 | 10:07 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
What would be nice is if there was a k member or arms that moved the wheels slightly forward from stock. It's too bad they screwed them up in the wrong direction. Even then I'm not sure it would be worth the piles of money they get for these things.
Old Jul 8, 2011 | 03:40 AM
Rich92 RS's Avatar
Transmission: T56's
Its probably just the angle of the picture cause after measuring, the rear has a gap 3/8's larger than the front. Not a big difference but I don't expect to see a huge gap difference like others have had. How far back to you think the wheel will move once compressed? I cant compress it as I already took it apart.
Old Jul 8, 2011 | 11:54 AM
87350IROC's Avatar
Car: 87' IROC
Looks perfect to me from the pictures.
Old Jul 8, 2011 | 12:07 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Look good to me. It seems hit or miss if the wheels are centered correctly or not with Spohn K member.
Old Jul 9, 2011 | 09:38 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
If they moved the wheels forward then you would have a longer wheelbase, but more importantly, would put more weight behind the front wheels which is very good for handling and even rear wheel traction.
Old Jul 9, 2011 | 01:42 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Just realized you have stock A arms. You should be good to go!
Old Jul 9, 2011 | 01:57 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Yes, and the neat thing about our cars is that it is also very easy to move the rear axle forward an inch or more. I've done this and it is not visibly noticeable at all. One inch fwd up front (to match the rear) would be awesome although you would have to do some trimming at the front to make it work.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
