Shocks/Springs question
Old Jul 13, 2011 | 12:46 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Okay, after doing a large search a few million times, I've come to the conclusion that Koni Yellow's are a fairly good lineup for just about everything you throw at it.. the question is - would these also be a sound option for a car geared towards drag racing and not necessarily handling/cornering characteristics considering they are adjustable? I just need a direction because I've replaced everything else EXCEPT my suspension components, and I would really like to get that taken care of before this next semester hits like a ton of bricks. Suspension modification is new to me, so I'd like to just do it right the first time obviously.
Opinions? My budget is around the $1,000 mark (or I'd like to keep it around there, at least). Feasible?
Old Jul 13, 2011 | 01:28 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Shocks/Springs question
Thats one thing Im not really sure about. Im not sure Konis are as effective at getting the weight transferred as a set of drag shocks would be.
Old Jul 13, 2011 | 09:28 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
If the car is going to be for mainly drag racing, Konis are not going to be the right choice.
With that $1,000 are you looking to do just the shocks and struts or all of your suspension? Personally, I do not know of a way to get your suspension set up with aftermarket parts for that price. You will be bale to weld up your PHB and LCAs to give it a litte more reinforcement, but to go and redo all of the components that people normally buy will run you more than $1K
Old Jul 13, 2011 | 01:26 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I meant just the struts and springs because mine have every bit of it's entire life on them. The other stuff I'm aware about, and they range from $300-750 depending on the part. So - $1,000 on struts/springs.
- Actually, I did a little digging on Jegs. Looks like Lakewood makes some components. Fantastic. Anyone here used a set from them?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
