What is stock ride height?
Looked in the GM service manual for my 91 TA but couldn't find any numbers.
What is the height (in inches) above the ground that the rockers of a stock 3rd gen car would be?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: What is stock ride height?
There doesn't seem to be any official number. I would guess that IROC's might have a lower stock height than V6 cars.
However, the rough guess seems to be about 28.5" from what I've seen.
Instead of spanking off about a bunch of ... spank-off, go here and see what they looked like rolling off the production lines.
https://www.thirdgen.org/forums/hist...od-1986-a.html
https://www.thirdgen.org/forums/hist...ory-buffs.html
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Stock WS6 springs on my car and I'm at JUST under 28in in front from fender to ground and 28.5 on both rears.
I'm about 1" higher than the stock dimensions posted here, with NEW springs from Rock Auto. I'll give them a month or so to see if they settle in. Worst case is I cut 1/2 coil off.
Car: 1989 Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: Stock 9bolt posi
I cut a full coil off the front and rear on my WS6 Trans am and it sits about 27" front and back, with the front tires 225/50 and rears 245/50
Genopsyde
Oct 7, 2015 08:35 PM
sailtexas186548
Aug 26, 2015 03:32 PM
Linson
Aug 21, 2015 02:12 PM
