which shocks with drop zones
Old Jul 17, 2011 | 12:17 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
like the title says. I just order a set of drop zone springs for my car and it could use some new shocks as well. I was going to go wtih monroe sensetracs but after some reading those might not be the best. Any suggestions for a decent shock for a lowered car that won't break the bank?
Thanks,
Old Jul 17, 2011 | 05:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: which shocks with drop zones
if you're looking at stuff in the sensatrac price range, grab yourself some kyb's. probably the best you're going to find in that price range
Old Jul 17, 2011 | 08:17 PM
fonzie85's Avatar
Car: 89 IROCZ
Do they perform well on a lowered car?
Old Jul 18, 2011 | 06:02 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
many people use them with the eibachs with good results, i'm in the process of installing my drop springs (forget which brand, got em from the classifieds here) and using GR2s on the fronts and gas adjusts on the rear.
Old Jul 18, 2011 | 11:51 AM
fonzie85's Avatar
Car: 89 IROCZ
ok thanks!
Old Jul 18, 2011 | 12:48 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
just want to give you heads up on the dropzones. they lower the front a ton. way more then advertised. prolly an inch more. and mine raised the rear about 4 inch's. thats just on the half dozen or more people that i know have installed them and uninstalled them. needless to say i uninstalled and got me some sportlines. as far as shocks and struts i have kyb agx struts up front and qa1 24 way adjustables in rear. love the way they handle. you will need some some aftermarket upper strut mounts to help out with more strut travel in the front.
Old Jul 18, 2011 | 03:40 PM
fonzie85's Avatar
Car: 89 IROCZ
Anybody else with dropzones have this problem. I did some research before buying them and didn't see anything about this?
darwinprice
17
Oct 11, 2015 11:51 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
