need some help lowering my camaro
Old Jun 26, 2011 | 09:49 PM
silent420wolf's Avatar
Car: 92 Camaro z28
Engine: LQ4 6.0L Vortech w/ aluminum heads
Transmission: 4l60e
Axle/Gears: 3.42s from 99-02 WS6
hi there, i am looking at an air bag system for the thirdgens. my questions are, with an air bag system do i still need adjustable panhard bar and trail arm relocation brackets and adjustable torque arm? second will the same years s10 spindles fit thirdgens directly since they share other common parts...thanks alot for the help
Old Jul 18, 2011 | 02:46 PM
Car: 92 Camaro z28
Transmission: 4l60e
Re: need some help lowering my camaro
does anyone have ideas or knowledge about this. i have spent enough money on my swap to do trial and error. please help
Old Jul 18, 2011 | 05:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
s10 parts dont fit, not even remotely close.
an adjustable panhard would be better than what you have, so at least at the set ride height of the air system, you have start with the axle centered, but when you drop the car, the axle will still move to one side as the car settles. Only way to reall get rid of that is to use a watts link setup instead, which is available in the aftermarket $$$$$, or build your own if you are so inclined.
the other parts are not really needed. The air system should have a height at which you drive the car, and thats where the suspension setting need to be set for. When you change the ride height, everything goes to pot, and there is no way to change it everytime you park and want to lower the car.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86camaroman201
Aug 19, 2015 04:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
