Hey fellas,
Sorry if the answer is out there, I've tried searching.
Will I run into fitment issues with the following exhaust set up and a set of UMI subframe connectors?:
Hooker 2055 headers
Magnaflow 93441 cat
Hooker 16823 catback
For those of you with UMI SFCs, how is your cat clearance? Is anyone running this combination?
I'm in the middle of an engine swap so there's no exhaust on the car now. Should I wait until the new exhaust is hung to weld up the subframe connectors?
Hooker 2055 headers
Magnaflow 93441 cat
Will your cat still run down the passenger side like factory?
One thing we do is keep the passenger side in two pieces so you can adjust it around different exhaust systems... I never hear any issues.
Thanks!
Ryan
Thanks!
Ryan
Yes, this is a factory replacement type setup.
They should work just fine for you. Hopefully someone with this set up can chime in as well.
If I can help anymore please ask. Thanks!
Ryan
Ryan
