steering issue
Old Aug 5, 2011 | 05:52 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
steering issue
lately i have been noticing that my steering wheel moves back and forth a little bit when driving and is pulling to the right alot.
i talked to one mechanic and he said that i probably needed my whole suspension overhauled.
for parts and labor he said i would be charged a little less than $1000.
what do u guys think? should i go with this or look for another mechanic.
btw i would do the repairs myself but i dont have the time to do it.
Old Aug 6, 2011 | 07:15 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: steering issue
23 year old car and my guess is the front steering parts are shot and need replacement & alightment. Parts are about $300 +labor so shop around.
Old Aug 6, 2011 | 07:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: steering issue
You might reconsider as the work isn't very labor intensive. There are some stickies at the top of the page that will provide some ideas.
JamesC
Old Aug 6, 2011 | 03:21 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
Re: steering issue
well i think i may have solved the tire, came acrossed an article on the web about tire belts breaking and causing the symptoms. so i go out and look at my tires and sure enough my tire looks to have a broken belt in it
Old Aug 6, 2011 | 03:44 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
Re: steering issue
sounds like a tire to me, thats exactly what it does, hopefully thats all you need
Old Aug 17, 2011 | 01:24 PM
acsvendsen's Avatar
Car: 89 Camaro RS, Black exterior,
Engine: Stock 305 TBI, K&N air filter
Transmission: stock 700r4
Re: steering issue
I have this same problem except to the left, but also with some added tire wear to the passenger front tire. I've been contemplating if it isnt the inner and outer tie rods being worn out. Any idea? It also is a bit looser stearing to the right and a bit more stiff turning left.
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Mar 18, 2019 08:29 PM
deracer
Apr 11, 2016 12:04 AM
sunbound
Sep 5, 2015 11:52 AM
backtothe80s
Sep 5, 2015 12:39 AM
