Anybody using BMR K-member with Ground Control weight jacks?
Old Aug 10, 2011 | 12:20 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Just wondering if it's a compatible combo. The stock K-member has a pocket that holds the spring both on inside and outside of the coils. The BMR K-member has only a cylinder that holds to the inside of the coils. That's the only thing that will hold the weight jack in place.
Old Aug 11, 2011 | 05:32 PM
87350IROC's Avatar
Car: 87' IROC
Re: Anybody using BMR K-member with Ground Control weight jacks?
The GC adjuster will most likely fit loose on the BMR K-member. I assume the K-member spring holder's outside diameter is roughly the same size as the inside diameter of a 5.5" OD spring. That was the case for my Spohn K-member. The GC adjuster has a larger ID than the spring if I remember correctly. So what I did is slit a heater hose and put it on the edge of the adjuster. That created an interference fit between the adjuster and the k-member. It also acts as a noise and vibe barrier. I have had no issues with this setup.
Here you can see the fit is snug. The interference fit is what is preventing the adjuster from falling.
Old Aug 13, 2011 | 01:46 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
What length springs do you guys run with the weight jacks? I've got a racecraft k member and will be using weight jacks.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Ducati900ss
Sep 2, 2015 09:05 AM
