Power Steering Filter
Old Aug 27, 2011 | 08:56 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Anyone ever or currently using one of these aftermarket power steering filters? Was thinking about installing one on my car.
http://www.summitracing.com/parts/AAZ-20-0038F/
Old Aug 27, 2011 | 09:42 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Power Steering Filter
our cars have these?
Old Aug 27, 2011 | 10:15 PM
MY87LT's Avatar
Car: 1987 Camaro LT
No they do not. I was thinking of adding one.
Old Aug 27, 2011 | 10:49 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
What would it actually do? Our cars don't have one stock..
Old Aug 28, 2011 | 10:33 AM
MY87LT's Avatar
Car: 1987 Camaro LT
I'd figure it wouldn't hurt to have some filtering properties on the power steering fluid. It would go on the lower pressure return line which is easy to work with. Other car manufacturers use a filter for their power steering, why not ours? And besides, it wouldn't deviate from stock look as all I would have to do is replace that short piece of hose and i'm back to stock.
Old Aug 29, 2011 | 12:14 PM
Not sure why this would be a good idea...
For an off-road Baja or Dakar racer, maybe; for one of these .... cars, it would be basically zero bang for LOTS of $$$$, and extra dead weight in a bad place to boot.
Old Aug 29, 2011 | 12:50 PM
That's what I was thinking.. The necessity of this is probably zilch.
Old Aug 31, 2011 | 07:14 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
However, if you ever have a pump or steering box go bad, it's a good idea to install a filter in the system after repairing and/or replacing pieces. The filter then will collect up any trash left in the system by failed components.
Course the $2 filter that slips inside the return line (looks like an AC orifice) is adequate.
Old Aug 31, 2011 | 11:39 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Since the P/S pump is used as it came with the serpentine kit I got off of Ebay, I wanted to use the filter to clean up any possible contaminants. I did flush it but just wanted to be sure I have a really clean system.
Old Aug 31, 2011 | 11:51 AM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
dont see the benefits... when I aqquired my 82 from the original owner 4 yrs ago it had approx 160k miles on it, the factory steering box was still great, tight and quiet.
In an off road vehicle exposed to much more dirt/dust etc.. maybe
Old Aug 31, 2011 | 12:09 PM
MY87LT's Avatar
Car: 1987 Camaro LT
On my old set up with the original power steering pump that came with the car and me being the second owner, I would not even consider it. But who knows how long the pump sat and I also converted to Red Line synthetic P/S fluid.
Old Aug 31, 2011 | 12:26 PM
How is the red line synthetic working for you? I was thinking of putting Royal Purple synthetic PS fluid one of these days.. Any difference in noise / feel in the steering?
Old Aug 31, 2011 | 12:37 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Originally I did hear some noise but that's because I didn't "burp" the system properly but went away after I did. As for steering response, it may be psychological, but yea, the steering seems to be more responsive.
Old Aug 31, 2011 | 01:07 PM
I'm sure the synthetic is better.. I have a Lee 670 box that progressively got loose again (strange) but I was thinking about putting in new fluid when I re-install it.. I can't imagine synthetic fluid hurting anything.
Old Aug 31, 2011 | 01:42 PM
MY87LT's Avatar
Car: 1987 Camaro LT
It shouldn't. But with all synthetics, if there is a place to leak, it will with a hunger. LOL
Old Aug 31, 2011 | 02:06 PM
ahh yes true.. Everything is new in my system so it should be all good. I'm just going to replace the hoses with stainless braided ones with an fittings for the extra security and peace of mind.
Old Sep 1, 2011 | 06:05 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I need to get a new low pressure hose myself. It's the original and leaking a bit.
Old Sep 2, 2011 | 09:31 AM
I just need to know where to get the hoses and which ones to get. Low on the priority list but I still want to do it eventually, actually I wanted to change all hoses to stainless braided for the look but mostly for the durability and peace of mind.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
