How do I get these apart???
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Sorry to ask probably such a dumb question, I searched but couldnt find it nor did it say in my chilton manual.
Anyways, how do I disconnect the steering knuckle from that steering shaft? The pic shows where I need to get them apart. It is right on a fitting.
I took off the nut but the bolt just turns freely, the knuckle doesnt lift off?!?!? What am I doing wrong? Any help would be greatly appreciated. Thanks!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How do I get these apart???
Put the nut back on, just a few turns, then beat the crap out of it with a hammer to force it out of the hole.
Engine: 4++,350 & 305 CIs
smack the poop out of the side of spindle arm rite by where the tie rod stud goes thru until stud falls out..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you're not trying to save the tie rod ends then just hitting the stud is fine. If you plan on reusing the ends then hitting the side of the knuckle works fine. Get a big hammer and don't be afraid to hit it.
Car: '91 TA vert
Engine: turboLSx
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
air hammer + ball joint fork attachment =
But like alky said:
Not gonna reuse it? Beat the crap out of it.
Gonna reuse it? Pickle fork or puller tool like pictured.
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Engine: 5.7 LSX
Wow! I never expected "Beat the poop out of it" to be the proper answer! But hey, it worked! Thanks guys. Im redoing my front end, new k-member, control arms, brakes and coil over conversion, but keeping the stock steering components. This was boggling my mind! Thanks again for the tip!
Car: 87 IROC L98
Fancy tools are not required when a big hammer gets the job done just as easily.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
BFH, nuff said...
