Drag Ladder Bar/Coil Over??
Old Sep 12, 2011 | 09:37 PM
Bradfield's Avatar
Car: 88 IROC
Engine: 502 BBC
Transmission: Turbo 400 RMVB w/transbrake
Axle/Gears: 40 spline/3.73
I have an all out drag car, 88 IROC, BBC, Runs 10.7's on motor, haven't sprayed it yet, but will run low to mid 9's on nitrous. Car has a ladder bar rear suspension, with coil overs, and there in lies the issue: I do not like how the coilovers are mounted. There is a solid steel rod that ties the rear coil overs together, the coil overs are bolted on each side of this steel rod. I'm looking for some other mounting options for the coil overs. The simplest would be to just weld the steel rod in place, but looking for pics of what others have done.
TIA,
Brad
Old Sep 12, 2011 | 11:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Drag Ladder Bar/Coil Over??
Take pictures so we can see how your system is mounted.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
aharvel50
Sep 21, 2015 07:31 PM
