Panhard bar??
Old Oct 4, 2011 | 08:13 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Panhard bar??
Pulled the rearend to swap some gears and noticed my panhard bar is bent and slop in the bushings so I figured I'll get a tubular one (have tubular torque arm and lca's already). Rearend is a little off center (probably because its bent?) The car isn't lowered I'm running L60s, so I'm wondering if I should get an adjustable or non-adjustable one. I'm thinking the bar should re-center the rear since its not lowered. I read good things on here about founders I can get a non adjustable shipped for like 60 bucks. I'm not sure how there adjustable ones are? Any input is appreciated thanks
Old Oct 4, 2011 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Panhard bar??
Its a crap shoot really, depending on a lot of variables, the rear may or may not be perfectly centered with a non adjustable/stock type piece. that said, it may or may not even matter. Usually only if you are very close for tire clearance.
i would spend the extra couple bux and get one thats adjustable, thats just me.
Old Oct 5, 2011 | 08:01 AM
UMI Performance's Avatar
Re: Panhard bar??
Even from the factory the rear end is not always centered. If you are seeing issues now with the rear end being centered I would highly recommend spending the extra few dollars on the adjustable item.
We offer a nice adjustable panhard bar, made here in the USA, TIG welded, chromoly components and glossy powder coat.
www.umiperformance.com/2029
If you have any questions please ask. Thank you!
Ryan
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
